April 23, 2025, 08:36:24 AM *
Author Topic: Brake lights not working with hand lever.  (Read 819 times)
pocket aces
Tampa, Fl
« on: March 20, 2025, 07:10:48 AM »
Brake lights work with the foot brake but not with the hand lever. Where should I start to diagnosis the problem?
h13man
Indiana NW Central Flatlands
« Reply #1 on: March 20, 2025, 07:45:00 AM »
Check the switch at the MC for continuity. Should be zero reading at rest so to speak.
Avanti
Stoughton, Wisconsin
« Reply #2 on: March 20, 2025, 08:40:15 AM »
Probably the points inside the switch need to be cleaned. The switch is fused closed but can be opened by cutting the plastic river top off and opened  and cleaned. The small mounting through bolt will hold it all together when installed. Than you can order a replacement.
« Reply #3 on: March 20, 2025, 09:26:11 AM »
At the lever, disconnect the two wires. Remove one screw and then spray some contact cleaner into a very small hole in the switch housing. Operate the button with fingers several times. Replace and test again. Replace switch if no joy.
Challenger
« Reply #4 on: March 20, 2025, 05:20:42 PM »
If it is the switch and cleaning is unsuccessful, a new one can be had for around $24.00
https://www.partzilla.com/product/honda/35340-MGS-D31?gad_source=1&gclid=Cj0KCQjw-e6-BhDmARIsAOxxlxUzuip8pq8aW0SGLl5KOxqpphSODaBSCZ5Gy4ZNuWj-Fqt1sJBGc4waAsp5EALw_wcB
« Last Edit: March 20, 2025, 05:23:42 PM by Challenger » Logged
pocket aces
Tampa, Fl
« Reply #5 on: March 21, 2025, 07:25:25 AM »
Cool, Thanks guys i'll check it out this weekend.
