April 23, 2025, 08:21:08 AM *
Author Topic: Rebuild the waterpump  (Read 1145 times)
Angry Turtle
« on: March 15, 2025, 12:00:52 PM »
 Anybody got a video or instructions to rebuild the waterpump. Just don't want to go into it blind. Thanks
« Reply #1 on: March 15, 2025, 04:16:37 PM »
Sorry: Never heard of anyone able to do that. I suppose your seal is leaking. As an FYI, before you remove it, drain the oil first.
h13man
Indiana NW Central Flatlands
« Reply #2 on: March 16, 2025, 07:29:02 AM »
Two o'rings is the extent of a rebuild. The draining of oil? Please explain as I've done coolant service before without draining the oil though I didn't remove the water pump but I'm curious as to why.
https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500c-a-valkyrie/water-pump
Timbo1
Tulsa, Ok.
« Reply #3 on: March 16, 2025, 08:59:15 AM »
Here is another thread that talks about the rebuild of a water pump.
https://www.valkyrieforum.com/bbs/index.php/topic,129759.0.html
« Reply #4 on: March 16, 2025, 02:17:59 PM »
The water pump is driven by a slotted drive in the engine. If you pull the WP, the oil all comes out through the same opening. An O ring seals off the water from the crankcase.
h13man
« Reply #5 on: March 17, 2025, 07:49:45 AM »
Thank you for the heads up.
« Reply #6 on: March 17, 2025, 09:11:05 AM »
YES, removing the water pump without draining the oil first, makes a HUGE mess.
Don't ask me how I know.....
Hay  Cool
« Reply #7 on: March 18, 2025, 05:59:50 AM »
Hay  Cool
Yup, been there, done that, same results  Roll Eyes
Joe333x
Boston
« Reply #8 on: March 18, 2025, 06:04:32 AM »
From what I understand the water pump from the GL1500 will work on the Valkyrie you just need to replace the cover with the one from the Valkyrie.
« Reply #9 on: March 20, 2025, 05:34:04 PM »
That's really cool if it works, Valkyrie waterpumps are "unavailable". I bought a nice used one
"just in case" recently. Punisher just bought a (non-OEM) rebuild kit. There's one of the
radiator hoses (the one with the slinky on it if I remember correctly) that is unavailable.
Ebay has multi-colored silicone replacements... anyone ever tried one of those?
Joe333x
Boston
« Reply #10 on: March 21, 2025, 06:57:09 AM »
This is a quote from a member on the Valkyrie Facebook group. If you're a member of the group just search water pump you should see it come up. I can't confirm since I've thankfully not had to deal with it but figured I'd pass along the information.
Tim Orr the water pumps are the same but the front face cover on the two pumps need to be switched. The valk water pump front hose bib need to go on the new Goldwing water pump. When changing your water pump make sure to drain oil and antifreeze before pulling or you will have a mess.
