Dave,
I don't know if Bob is taking on new work or not. If not, I can help you.
If you really are intent on doing it yourself, I can advise you on an ultrasonic cleaner and solution, as well as parts.
If you want the work done professionally, I can do that. Here is a description from my web site:
PACKAGE INCLUDES:
• Your Carbs Rebuilt.
• They are balanced and tuned on the test engine.
*Choose this package if you want to have your carbs rebuilt and returned to you.+
Set will be refurbished and in excellent condition.
CARB REBUILD:
Carbs are completely disassembled, ultrasonically cleaned, and reassembled after verifying passages are clear.
New parts – 156 total:
• All O-rings and gaskets
• K&L Bowl Needle Valves
• Bowl screws
• Slow and main jets. 35/100 (stock) or jet for your exhaust if not stock.
• Main needles
• Pilot screws, springs, washers
• Fuel Lines and clamps
• Air Cut Valve screws and tubing
• Crossover arm bearings and cotter pins
• Balance adjusting (flyaway!) springs as needed.
Testing Done:
• Air Cut Valves tested and verified working.
• Vacuum test bowl gaskets and drain screw O-rings seal.
• Balance (sync) carbs on the test engine with Digi Sync.
• Tune on the test engine.
Carbs will be shipped via UPS.
Whichever way you want to go, contact me through my website. I will see it sooner than the forum here. I am also a sponsor here.
www.valkyriecarbsandcustom.com
